Answer: There is no difference. The Max and Min values are the same no matter how the part is dimensioned. The tolerance is on the surfaces not the dimensions. The width can vary from 90.4 to 89.6 because each surface has a total tolerance of 0.4 based on the profile of a surface tolerance.
