Most holes will have both a size and position tolerance. This combination causes the hole to "act" larger and smaller than the actual size from a fit and shift stand point. The smallest the hole may act is called the inner boundary. The largest the hole may act is called the outer boundary. The inner boundary represents the closest the surface …
