The Y14.5 standard tells us we can use a pattern of features to establish a datum or datums (section 4.5.8). Unfortunately, the explanation that follows in the Standard only covers a pattern of holes at MMC. There is no support for using a pattern of features of size RFS. Where two parallel holes are used as a pattern to help establish a datum reference frame, it is pretty certain that two datum planes will result - one plane through the two holes and a second plane midway between the holes. Once more than two holes are used as a pattern to establish a datum, the resulting datum reference frame is unclear. This month’s Tip is to avoid using a pattern of more than two holes to establish datums when referenced RFS.
