Flatness and straightness on a unit basis are good controls to use when you don’t want an abrupt change in a surface. If you don’t limit the overall variation, however, a larger than expected out of flatness or straightness may result. For the part shown below, flatness on a unit basis of 0.2/50mm has been specified. Since the overall part is 200mm long, what is the maximum flatness variation there could be over the entire length of the part?
