- Translation of symbols and geometric callouts into plain English with one meaning.
- Tutorial Learn geometric dimensioning and tolerancing as you need it. Dynamic hot words instantly link you to easy to understand help screens with graphics.
- Rule Based Select the appropriate standard. The software will not allow you to build an incorrect callout.
- Units Conversion An easy conversion, with one mouse click, the dimensions and tolerances toggle between millimeters and inches.
- Technical Glossary Quickly look up unfamiliar terms in the extensively illustrated technical glossary.
- Inner/Outer Boundary Calculations The software automatically calculates the inner and outer boundaries of features of size. These values are frequently used for gage design and tolerance analysis.
- Customized Reports Easily generate reports of the translations and conversions which may accompany a print to explain unfamiliar symbology to others.
- Notepad To document instructions or assumptions there is a built-in notepad.
