Describes the condition on a surface of revolution (cylinder, cone, sphere) where all points of the surface intersected by any plane.
Describes a condition of a surface of revolution in which all points of a surface are equidistant from a common axis.
Is the condition of a surface having all elements in one plane.
A condition where an element of a surface or an axis is a straight line.
Is the condition of a surface, axis, or centerplane, which is at a specified angle from a datum plane or axis.
Is the condition of a surface, line, or axis, which is equidistant at all points from a datum plane or axis.
Is the condition of a surface, axis, or line, which is 90 deg. From a datum plane or a datum axis.
Defines a zone within which the axis or center plane of a feature is permitted to vary from true (theoretically exact) position.
Is the condition permitting a uniform amount of profile variation, ether unilaterally or bilaterally, along a line element of a feature.
Is the condition permitting a uniform amount of profile variation, ether unilaterally or bilaterally, on a surface.
Is the composite deviation from the desired form of a part surface of revolution through on full rotation (360 deg) of the part on a datum axis.
The simultaneous composite control of all elements of a surface at all circular and profile measuring positions as the part is rotated through 360.
