When measuring nearly every geometric control, the indicator or CMM probe should move normal (at 90°) to the surface. The exception is circularity when applied to a conical surface. Circularity requires that the movement be in a plane normal to the axis rather than the surface. If the movement for other geometric controls is not normal to the …
