On simple parts the dimension origin symbol may be used very effectively. This bracket mounts on the shorter surface as shown. A lamp is attached to the longer surface. It is desirable to inspect the 38mm dimension by mounting the part on the functional shorter surface. By using the dimension origin symbol, it is required that this dimension be inspected by mounting the bracket on the shorter surface. The same control could be accomplished by calling out the shorter surface as a datum feature and applying a profile of a surface control on the longer surface.
This tip was originally released in May 2001.
